  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
sorry went to feed cats
nah Cams cool about it. :P he suggested it
So I assume you pair are having a sleepover at Cams if you intend to go maggotin.....err clubbing:D
Cheers
Ken
no ken what we are doing is driving to citywest in Liz's car saying hi - then leaving Lizs car at kens in west perth for the night - brings the taxi bill down a bit and we get to say hi to everyboady before they leave :P
haha 4wd is cool fun, long with sandboarding, putting areosole cans into the fire, getting pissed out in the middle of nowhere ....... love it - so much better than hiking haha
How would you know.??
You said hiking was something you did when older.
So you lied
Ahhh haaa!! , a secret closet hiker.
Come out and confess !!
we know your secrets now!!:P
Cheers
Ken
no ken what we are doing is driving to citywest in Liz's car saying hi - then leaving Lizs car at kens in west perth for the night - brings the taxi bill down a bit and we get to say hi to everyboady before they leave :D
Kens.
Hmmm , I think I'm getting to her....:P:D
Cheers
Ken
getting to me? what - nah sorry if that sounded grumpy wasnt meant that way :D
Read your post babe.
You said drop at Ken's ,not Cams:D
As I said , I'm getting to her , she can't get my name out of her head.
I will have you in my power
mwahahaha!!
Come little one....
Sorry , got a bit carried away.:P:D
Cheers
Ken
Originally posted by Sneeza
Niz - where are we sleeping tomoz....
* Ken puts hand up *
No , bugger it
* Ken puts BOTH hands up *
It's alright dear , there just some friends having a sleepover here....:P
cheers
Ken:Pimp:
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
