  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hehe thats right :P nah theres only one bit im a bit hazy on ..... drunk to much went and plonked myself down on the couch - thought i was going to be sick - and its pretty hazy right up to the bit where i rushed off to the toilets thought i was going to be sick - but i wasnt and after that i came really good and went all hypo hahaha
theres just drinks come from every direction when we are out ...... and u cant say no to them haha
it is - ask 33spec2 and cam .... they know all about our antics :P
certain amount of babysitting is involved tho - otherwise we get into too much mischeif...... last weekend Liz got thrown outta the Rise haha
haha Liz just staggered past the bouncers in the exit she used as the entry .... got to the top of the stairs and this bouncer comes running after her and told her she had couldnt come in after that :P
probably haha Liz was a staggerpuss ..... i was ok....... this weekend it was the other way around :P
its all good fun - we are both gone thru a bit of a rough patch lately ..... so its just our stress relief away from reality haha
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
