  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ladies coming back off maternity leave and she's the bosses pet :D
hehe bayley sent me this thing on how to know your car is rice .....
Think i should try this one ;) :You put your automatic car in neutral at every stoplight in order to roll it back and try to fool other people into thinking you have a manual transmission
oh and this sounds familar ... haha You add a super tall rear wing, and a hundred pounds of aftermarket ground effects, neon and stereo yet you gut the interior and yank out the rear seat for weight savings.
makes me laugh :(
Your baseball cap is always on backwards when you drive (the first sign of mental retardation, wearing your clothes backwards... BE).
^ my ex used to do that .... haha embarrassing on a 28yr old! :D
haha ur my favourite Alex .... true :)
Well my last few weeks here were going to be hell - moving near the big booses office (who i am now PA too) and my computer would face right into his office :( ..... he's put me in charge of the moving of everybody - big mistake .... i now told the building supervisor of my predictament ..... he's found a way to stall the move ..... so hopefully by the time the move does happen i'll be outta herre!!
But yes at the moment i dont give a phuck about work ..... actually if anything i just want out .... im really wishing Ros would come back soon!! ..... i think i may stick with temping tho .... i get too bored if im in one place for too long it just gets boring ..... maybe this is why im still single hahaha :D
hey i opened up the Kalamunda business services directory thing mi jig u get ..... and flicked thru .... boredom .... came across Car Clubs ..... lo and behold ......... GTR CAR CLUB ...... didnt know there was such a thing!!
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
