  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
cam - you seriously need to do your homework on fuel regs and pumps.
Increasing the pump strength will assist in delivery of fuel pressure - but the effectiveness of this is severely limited by the stock injectors - and you need management to run other injectors.
besides this, you're probably not managing enough boost to justify an upgaded pump.
I dont know about other brands, but I know malpassi's let you squeeze more flow out of both the standard fuel pump AND out of the duty cycle of the standard injectors - and aftermarket regulators can provide a "backup" in-series regulator for the stock one (although the stock ones are pretty good anyway).
but until we start playing with post-fmic engines, both have limited use.....but might be worth grabbing if really cheap.
always had top of range oil in there so i cant say that over Mobil 1 that was in there before theres any difference..... there mightve been and im just a dumbass female that didnt feel it. *shrugs*
i dont know how many litres sorry .... my mech did it.
ah transmission oil hmmmmm ...... dont think mine is Redline .... i dun know ...... *runs to check service invoice* hahaha really should pay more attention when Slako talks about what he's done to my car!
Hey Erin - u always come on around my hometime - the indian pacific goes to perth but leaves from sydney. :D Left u an email for u in morning.
I have to go home now
*hugs*
Lauren
    • Haha no I'll do that one tomorrow. I've been ignoring it. It's the 5.0 one I'm taking about. (There is a little X to hide the 4.7 one if you want)
    • So I'm going to have to keep ignoring the 4.7 update, or whatever version it is? Poop. I was hoping you'd put me out of my misery.
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
