  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hehe nice one :)
i wanna get both my cars on the dyno ...... at same time .... with noone there to laugh at me .... particularly interested in the ZX for some reason.
See ya mark
nearly lunch time ......
true - but still i dont really want to drag them both down to a dyno day .... just me and whoever is driving the line .... i'll drive the ZX down ..... be very interesting ..... ZX been on dyno before but i dont know result it was to sort fuel problems .... it was running way too rich .... and at that stage i was pretty dumb about the car
hehe nah i do ok, i dont post heaps just in sporadic bursts
i should learn to stay off irc tho, i just get myself into trouble
oh, i went clubbing for the first time last weekend
goin to a party with wayne and then into surfers again on friday night... thats if he gives me the details of where im sposed to be meetin him
u queenslanders dont do much clubbing do ya?
in fact the clubs in surfers were pretty poor - well the melbourne boys thought they were wick ..... which make sme wonder what kinda clubs they are in melbourne!!
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
