  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Sneeza, just got your PM. Yeah the tyres ive got a temporary cos im getting better ones, so they are going to get fried over the next few weeks. I was doing nuts in a deserted car park last night and full drifting around the islands in the carpark.
Soooooooooooooooooo much fun:burnout:
Yeah IT is cool :O Unfortunately all my IT responsibilites are being outsourced in about 4 weeks :D
I will try to be there at 3.00 so I get the maximum time there as I will have to leave by about 4.00..... Hopefully I don't have any problems finding it :D I have heard about it alot but never been there :D
yeah I have never failed a unit hahaha thank god! Yeah english... ppl who do that crap are dicks.... they bag everyone for being "mainstream" but then all of them are the same... if you get what I mean. Like if you listened to anything else other than JJJ in radio studies.... jeez - you were like a dork or something.
Brett - IT is picking up at the mo... don't be too worried
