  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
nah i SHOULD have more in as my pay SHOULD have gone in wednesday then again it may not of cos i handed in my timesheet late .... will check at lunch anyway.
bloody car keeps me poor - its sitting on nearly $1000 worth of tyres thank u very much .... i was rich til them and the brakes and whatever else im constantly replacing on the phucking thing!
doof is;
....doof doof doof doof ....doof doof doof doof....doof doof doof doof
DnB is still essentially a 4:4 beat pattern, but the use of breakbeats and the emphasis on the baseline as a component of production allows for improvisation and variation.
whereas "doof", ie. house/trance/dance/antsinyapants music generally employs a four beat bass drum and has an emphasis placed on the treble melodies. "hands in the air"
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
