  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Sorry for the delay I got busy ;)
OK to answer everyone :)
I work for Ericsson looking after the new 3 mobile phone network...
QV1 is one of the largest buildings in perth..... Its the really big one with a flat roof :P
Yeah I had a quick chat with Cam about his phone.... they are pretty good when you know how to use them.... :(
