most places ive worked are!! maybe its just me - but i try n see good in everybody til they give me reason to think otherwise.
and you cant call it jsut a job cos you spend most your life in it :D
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
paul - one person yeah it doesnt bother me - like at new town this one girl hated me for god knows what reason - think its cos her boyfriend liked me anyway that i could deal with .... we worked in different sections and everyone else apart from Max i got along with. But here its like everyone against me!!! and i have no clue why!! and all its acheived is me not giving a phuck anymore and if i tread on their toes too bad but its really getting to me!!
