  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
it was pay day today $$$ *cha-ching* saving up for a rainy day .... actually if i really budget this week then with next weeks pay - i should be ok without a job for a couple of weeks .... cos its actually WITH a job i spend the money .... parking, lunches, fuel .... i should also be able to spare the money to have my brakes done - decided to do it when i ge the arse that way i dont have to worry about co-ordinating getting the car there then getting to work etc etc etc ....
i guess its not like im going to be battling - its just i prefer to have more than i need instead of less than i need..... i mean it only cost me $500 for 2 weeks partying it up and not scrimping on anything for those 2 weeks .... so im sure i can comfortably live off $1.2K for a few weeks in boring ol perth.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
