  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
my car needs its suspension upgraded to somehting a little stiffer, my brakes could do with a little bit of upgrading, and the powerfc, also the paint needs to be really touched up, the spoiler, front and rear bar, bonnet and drivers door need respraying....... probably should get the whole thing resprayed but i dont think that they could match my colour ;)
i want mine resprayed - a metallic purple - i wanted the R34 metallic blue - but i saw an R33 in that the other day and i didnt like it!!
Really i would like a colour that is like a cherry red in some light and a black in other light .... u know kinda chamelon but not ..... be way expensive tho!!
i think they have a name for it, like harlequin or something
i dunno, im pretty sure theyd be able to do it, i doubt it would be THAT expensive, i mean compared to other things
it was gonna cost like 600 dollars to redo my back bar and spoiler and touch up the bad stuff on the other parts of the body
but it would look shit with little bits done and little bits left fine
so it would be better to get the whole thing done in one hit
slip in qld just had his r31 resprayed, i wonder how much that cost him, i dont want a shit job done either, i want it done well, not with trims sprayed when they shouldnt be ect
i saw a 300zx resprayed, looked great, get up close, they pretty much taped the windows and sprayed everything, even the door locks
Hiya Everyone :wavey:
Quick question.... does anyone remember seeing a picture posted/linked to on SAU of a black Stagea with a R34 front on it.... I believe the car was in japan..... I remember seeing it ages ago and would like to find it again....
i hate xmas time full stop, more of that time where everyones so happy for nothing
theres no reason to be happy its just another excuse to rush out and buy gifts and crap, and theres always the gift that keeps on givving, a lovely dint in the back of ya car, everytime i look at my car i get a little angry
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
