  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
whos Spoonie .... sounds kinky :)
yeha havent been for a while - might go when im unemployed on a week day that way i dont have to fight with pesky kids to see animals.
lol make sure visit the wetland enclosure and penguine pool... me and Zoo people built it :) very nice ;) damm hard to clean
Originally posted by MrGTST
Hey Paul.... Do you know someone that drives a R32 GTR with plates 32GTR???? I saw it about an hour ago..... Looked pretty nice...
Ive seen it too - its Dark Grey eh? .... didnt wanna play with me either :)
