  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Paul ive got enough to survive VERY comfortably for a couple of weeks. :) Besides i dont spend anything when i dont work! I found that out when i came back for QLD .... stop working and all of a sudden my money problems clear up - go figure!!
Anyway i will go back to work - i just want a week or two off thats all :)
just washed the car. lookin sweet of course. and i went to the shop to get some cigs and the girl asked me for ID!! i was so shocked and offended. I told her i was 25 and cbf walking to the car to get my license, so just give me the cigs!..
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
