  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
will do paulie :D
yeah but its obviously going to be better than the last because the sport has grown hugely in popularity and that wouldve been one of the first ones they held last year wouldnt it? always improve ......
