  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha how was those Silvia dudes on the way back haha i pulled up beside them at the lights .... and i go "Learn to drive guys" :D and then took off haha they spen tthe rest of the time trying to catch up to me then beeped me as they turned off. Sorry about squeezing in between you n that 4wd drive .... i came pretty close to your rear end - but i didnt have to slam on the brakes or anything it was all fairly under control ..... it scared the shit outta Mel tho :D
yeah cos on mitchell freeway had to turn off to Leach hwy and they were being dicks and slowed right down ..... so i was right up their are swerving back n forth across the road then though phuck this shot past them and back in front of them .... and thats when we got to the lights to turn onto leach i told them to learn how to phucking drive haha their mouths just fell open and didnt know what to say then they went "hey" and lights changed and i booted it.
oh after you guys turned off i pulled up on leach and guy beside me in 4wd pulls up and shouts out the window to me "So did ya win?"
Cant understand why you didnt pull a "Peelie" for the RAC guy Liz mightve given you a free lube as well as your jumpstart :D
Yeah you n I pulled a few Ch33ky stunts today but its all good 'no cars were harmed in the making of this cruise' :D Knew Mitchell freeway was going to be fun.
haha nah we went to the Rivervale ..... our bottle of wine arrived before the food and i hadnt had any breakfast etc so it went straight to my head it was pretty funny ..... food there is yummy tho :D wouldve invited you but i thought you may of wanted to get your car home!
Originally posted by Sneeza
the difference between us pulling "cheeky's" and cheeky driving like a *****tard - is that we really do have skylines..
:lol:
Plus by the time you cut someone off and step on it your far far away before they have a chance to go up ya arse :D my theory anyway ..... it was a pretty risky move me shoving myself between that 4wd and you but i didnt realise the lights had turned red ..... and i started apolgising to this guy in the 4wd that asked me if i won thinking ti was him i cut off ...... but he just looked at me weird.
Hey Ken ..... yes had fun :D we always find some unsuspecting piece of shit to play cat n mouse with :D
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
