  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hahah did you see my death glare Liz ...... i tell ya if i was staring at ice it wouldve melted .... i was pissed off that had no respect and were getting that phucking close and at one point touching my car!!! i want one of those "move away from the vehicle" sirens!!
I like Russ's idea about putting a GT wing on the back of the ZX tho ..... :D
Originally posted by G0DF4Th3R
Ken - how does he know ure last name? do u even know the guy?
Wouldn't know if I knew him or not.
Ahh , the wonders of the faceless internet, where people can say what they like without fer and then disappear...
This is why I asked him for his real name.
Unfortunately , I am known by a lot of people in, and on the fringes of motorsport which sometimes is not a good thing
Cheers
Ken:(
you know what i really would like to do ..... i would somehow like to buy my ZX off my folks ..... do a manual conversion on it ....and learn how to drift it ..... that car would make a mint drift car ..... it would be my version of a Racer :D ............... must find money first :D
Originally posted by Sneeza
I won't be here babe!! me and russ will be shopping in singas!
Sorry - its a bad excuse for a piss up - but still a piss up!!! I hope you find another job soon hun
She can't , well not full time.
We need her to do the washing , car cleaning , tyre changing , cooking for us 3 on the SA drifttrip. Hehehehe
Cheers
Ken
Hmm , that would be expensive and prooly not worth the drama.
You can buy those in Japland with an RB20 engine in already ( Jash has one ).
Now that would be cool:D and no injector/wiring issues
Cheers
Ken
Niz - someone offered me a 11sec rotor for 20k :D kewl car to run around in eh? not sure my parents would like it though, showed my mum the car and she freaked out
Only if it was in a series 6 or better RX7.
In an RX4 or 3 then don't bother, it would take a lot to make it stop or handle.
Cheers
Ken
its not just a matter of doing a manual conversion? needs whole new engine ......
but that car has sooo much potential and i doubt anyone else is going to realise it ..... and i just cant part with it ..... and i need a set of trainer wheels :D ..... but i know - parts are hard to find and expensive and its all too high maintenance ..... but i have a dream :D
Ken Ken Ken...... a bitch slapping is in order
OK bitch , I'm coming round for my slappin...:D :D
* ooohh slap me hard , slap me quick , slap me on my rythmn... *
Hehe
Ken
Ken - its the Capella, all done up using huge ass brakes and it used to be daily driven by its owner who owns a whole bunch of other cars. thing is the owner got a couple of 11 sec runs in and the car has been sitting in the workshop for 3-4 months. its got a nice interior all retrimmed. i thought it would be cool to run around in.
its in Msia so thats around AUD8k
They do make cool drift cars but underbonnet temps , wiring and turbo issues make them to hard to maintain.
That blue 300zxTTDD I had was a good example of use it , abuse it and sell it..:D
cheers
Ken
Capella ???
You don't mean an old RX2 ??
dear god , I hope not Bam. There has got to be something better than that to buy in Malaysia.:D
Cheers
Ken
nah plan is to take on a short term temp assignment that ends before i go to SA :D
Cool , so you ARE ok with the washing , cooking, hand feeding , servant thing then ??:D :D
Hehehe
J/K
Ken
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
