  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
dan - provided that they do not impede your vision they are ok.
Although it's best to have an inline switch for the lights, so that if you get pulled over you can flick them off.
I think there is an ADRule about having illuminated gauges above the top of the steering wheel or something. Though I don't know how that works for heads-up displays..... :shrug:
Im going :D
Dan - just go through taka or better still - greenline.co.jp
Most of the local people have had the shits with stockingperformace gear since everyone just gets it direct anyway.
get the trust pillarmount from greenline too. they're heaps cheap!!!
You'll find no-one will have them in stock and it will take you longer to get it in via them than through japan direct anyways.
    • Oh please, when has anybody really been "done" when they say that? 😂
    • The part where you claim the car "is done" means you won't...
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
