  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeah Richie SAU has their own portable laundry mat ..... Paul has the washing line .... Cam has the ironing board :)
haha Dan :D she doesnt bite .... well you can tell if shes in a bad mood - its the only time her car gets a thrashing!
im not being bitchy! haha paul remember that Silvia with your rims on it on Saturday .......... :) ....... *hides from a slapping*
Hmmm i might put a more fancy rear wing on mine .... veilside or something ..... need to shop around .... then intercooler then getting rid of Gay Holden Clubby Exhaust *see i even call stuff on my car ghey ... but thats ok cos i didnt stick that exhaust on so it in noway reflects my taste!*
no probs Ross - you mustve got thru that novel in record time ;)
oi richie when ya ready to buy the front mount let me know .... ive discovered if you go into a shop to buy two of something they tend to be a little nicer price wise :D
Originally posted by Nizmo
oi richie when ya ready to buy the front mount let me know .... ive discovered if you go into a shop to buy two of something they tend to be a little nicer price wise ;)
hows this i can get a 's type' HKS kit for $1400
or the Trust GReddy VSPL for $1550
just need the cash....:uh-huh:
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
