  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i could go a nandos dinner after gym :P
Good Boy Bam *hug* !!
Hey Richie n Alex :wavey:
Temp agency just called shouldnt be hard getting me short term work to fill some of the gaps before i go away which is good news :D
i don't really like drinking either bam, well actually only after leavers coz i felt like shit, but occasional drinkin goes down well :) it's like getting aqquainted again with a long lost friend :D
adrian :P
morning paulie
