  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
nah couldnt get a restraining order .... theres good and bad with everyone .... its jus ttha the had both and two different opposite extremes i really do think he's got psychology issues that a proffessional needs to sort out ...... his brother is the same and his brother is almost the same age as you ken ... actually would be around the sam age as you!
What , 21 ??
Cheers
Ken
haha no Alex is about 50 ..... his so Alexander is about 15 ..... oh and Alex and Andys dad is also named Alex ..... phucking Scottish!!
Sheesh
pick on Ken:D
I am nowhere near 50 young lady. hurrumph..
46 is nowhere near 50...
Cheers
Ken
its a Lexus bam
cant find that website .... addy is at work.
I wish !!
Actually it's a POS mazda ex courier van I cart crap round in.
Anyone want to buy it ??
puhleeeeeze:D
Cheers
Ken
Originally posted by G0DF4Th3R
man Ken's got a lot of cars
Huh , you can talk.
You got more houses in asia than I got cars:D
And chauffers, and bodyguards ( not that my body is worth guarding anyway ):P
Hehe
Cheers
Ken
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
