  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nobel Soul
zanda, well i did take it all with a pinch of salt, so i did my research and here is what i found...
240kW at 5250rpm and 450Nm from 2000-4500rpm
6psi turbo pressure
so, its got a small turbo, producing reasonable power - but a long throw and a poor RPM ceiling as a result. But, to it's credit it makes full boost at low revs because of it's high engine capacity.
that is what its set to as the standard, and the compression ratio is 8.7:1.  Being a 4 L engine it has alot more potential. I just wonder what ford got out of it before it reached danger zone.
I disagree with this statement - and not because it's a ford, although I do think that's why it's happenned.
When commodore moved to a turbocharged engine for the VL - they did so through a negotiative bargaining agreement with nissan - because Nissan were familiar with the engineering behind turbocharged engines.
they made a n/a 6, a turbocharged smallish six, and a V8 holden for the clan who are committed to their big block pushrods.
however, ford recognised that in order to sell cars to the modern australian market, any performance vehicle larger than a 200sx has to have big cubes. this is both what will make the car a sales success and a performance failure.
big stroke = big buckling forces = bent rods.
capa  http://www.capa.com.au/xr6.htm has already released kits that boost it to 350kw and they are working on a 380kw which they think they can achieve no sweat. [/b]
so it doesnt make much more power than a semi-stock GTR? which will do high 12s?
I just dont think people realise how much faster a car has to be to do tens.....so they make up some horseshit about 10 seconds.... I can't see it happening.
I also heard from a ford guy that the trubo can be set as high as 32psi, but i still got to verify that.
[/b]
I beleive that the ford turbo is a ceramic wheel - so I doubt it.
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
