  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
hahah i wouldnt complain about that Brett :P
so you off to melbourne again soon .... or grounded for a little while?
I will defianately keep that in mind ;)
Yeah I am flying back to Melbourne on Monday..... come home Friday night again. Will take my laptop and can hopefully do a bit of whoring next week :)
Guest Nobel Soul
Godf4th3r, well my old man was gonna get me a GTR R33, but i blew that chance, but he still owes me his promise, so its just a matter of chosing, and that is why i joined this site to learn more. But i have to wait until the end of the year he wants to see my uni results if i been f'n around or not. I think either an R34 or R33 GTR it all depends
