  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by zanda
richie007 has a new job.
it involves specialised work in a key security field
the pay is excellent and includes salary packaging with a new sportscar every 6 months and a significant clothing allowance.
haha i wish!!
Just a defence thing... nothing exciting.
hey kyles .... we gotta talk about PAS uniforms soon- think we should just stick to shirts - dont need making dresses on your mind when you got exams etc to concentrate on. :)
pay well - get your own office - staying in perth?
I cant wait for PAS, i reckon that it is going to be cool!!
I will definitely have to get the digi camera out for that one!
so have you decided what the girls are wearing??
ok guys the fun is over, and i was having a good day too...:)
haha
anyway, i am just happy that i have some direction now that i am getting out of the navy.
Just been chatting with Ken, he might have got us some redline oil cheap if we buy it in large quantities, anyone interested?
Niz, I'll be helping Docile at my place about when your having your brakes done, but can you come over after there done?
Hi niz,
I really dont mind making the dresses... give me somthing else to do to have a break for a bit. Trust me the designs i have chosen are easy as pie, wont take long at all. Ive looked at my uni time table and when my assignments are due, and i will be fine with a bit of spare time on my hands before the auto salon. I dont mind shirts either, but dresses tend to make me look slimmer hehe
im fine with dresses they are a good idea Kyles - its just im not going to be much use sowing wise and i dont want to put you under pressure but if you enjoy doing it - we'll be more than greatful for your help .... and if you need me to do something other than sow let me know :) dont think we should go checks tho - that tends to make people look fat. Red i think.
I'll come over after paul.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
