  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken, Just looked at the Drag calander, it's only Sunday Drags till the 1st of Oct, then Wednesdays start again.
Bugger, Every Sunday is booked for me until we get back from SA.
I have a GTech.
If I knew how to use it , maybe we could do some testing in conjunction with Micko and Danny , a straight quiet road and some two ways....
Cheers
ken
Ken, Niz's brake lines are broken, any good place to get a replacement?
Broken ??
as in split in 2 or just have some cracks on the outer casing ?
Cheers
Ken
Originally posted by G0DF4Th3R
so anyway, this guy with the GTR asks whose GTR is the quickest in Perth and how he's gonna go down to the Plex soon
and he boosts at 1.7
Hi Bam
The place is full of tossers.
Boosting at 1.7 bar is out of the efficiency range of most bolt on HKS twins.
Mind you , if he has a big single then I will shut my mouth.
btw , I think 11.5 from the Speedworks R34 is bout the quickest
Cheers
Ken
No worries Mat, more than happy to help, better than working:D
Ken, She had her disks skimmed, when they moved the calipers the brake line snapped, but there was obviously an old fracture in the line and it was squashed out of shape.
Bam, Quickest is a low 11 I think. 1.7bar isn't that much.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
