  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
come to think of it probably not - ive got to go pick Kyles up at 3:30 and also we've already got a cruise and i aint got a huge amount of money for petrol and stuff lately ...... might grab hold of mums fuelcard .... but all thats going to mean im going to go through two tanks of fuel just for the weekend ;)
Kym, Sounds like it will be very nice:D What stickers?
Niz, Brett rang and said that we will have an opportunity to go to Belmont to scope out the PAS area at about 4pm on Tuesday, wondered if you'd be free to give me a lift and check it out at the same time? No probs if you can't.
