  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken, If you get on can you confirm that all those injectors are 550's, and have been flow tested? It's just there are a few different colours, wanted to be 100% before we tried fitting them:D
I was a bit suspicious but they have been checked and tested by Rotomotion.
The other set was similar but seems to be OK.
Cheers
Ken
Originally posted by Micko
Jarradale somewehere I believe mate - might go down there after I drop Naomi off at midday
Forrestfield oh deaf one...
CBH grain terminal on Abernathy rd bout 1km North of the Tonkin hwy overpass.
Cheers
Ken
My last post, the one about me being a good painter, please disreguard. Ravings of a bored housewife I'm afraid. 2nd coat not so good. See how it looks 2morrow.
Paul, not going on cruise. Night shift tonight.
I got the UHF radio from Tandy today, 2 for $99. Uniden, 3Km range 40 channel. Anyone want one? PM me.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
