  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
paul - yea.. wierd when suppliers who are signed up for multi-million dollar contracts lie to you about things?!?! man - there's this little guy called manwell - and he's like the guy from faulty towers - no joke!! i'm gonna kill him... :D
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
