  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Nah same level - but i didnt have an office before - now i do - i share it with Kristen but she's cool - she's like me - when she's at work she's quiet and minds her own business ..... not like the other bitchy chicks over the East side. Im now West side ....*insert yo nigga here*
Final inspection on new house eh? must be so excited!!! No going back once you've entered the land of responsibility :P
yeah, it hit home last night when I started dreaming about painting stuff and planting stuff.... didnt sleep much after that.
Ive decided that Im not ageing prematurely. Im laying the base for a foundation of my future empire.
First you get the money,
then you get the power
then you get the Women,
but first you've gotta get the money.
oh and a cherry tomato tree .... see yeah you need fruit trees .... my grandma has a lot of fuit trees in her garden and it was always great to go over her house when your little cos the garden was a mean in itself. :P
around the back of belmont ..... i was driving through there the other day and theres some scummy bits of belmont but theres also some really nice parts! :P and its close to the city fairly close to home. Theres a part of Belmont called Flemington Downs near Belvedere St - i would buy near there.
My ultimate dream house suburb tho would be Floreat.
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
