Thats ok... I havent really read back yet... SO you have found another job then??? How is it??? What do you do??? :P
I go between west perth and perth ( we have offices in both ) .... I am thinking of a nice chicken and salad roll today :(
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
wont be into work til about 11 tommorrow cos of doctors app then i gotta come in casual gear cos im helping some division move - god knows why ive been volunteered to do it - so you probably wont see much of me tommorrow!
man i all of a sudden feel really sick and really hot and to top it all off the psyschopath at work has really overstepped the mark. Just want to go home n cry or something i dunno.
ooo icecream :( haha i know but i dont like creepiness that i have no control over .... some people are unstable and they are the last sort of people that need to have an obsession/crush on you :P
about 6:30
how was your day off?
