  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Lol @ Angel weird question - how much younger? yeah if he was a good package of coarse i would :) ! u considering it? ...
haha not sure about the bonnet poses .... thougts of the importscene skanks spring to mind when you mention things like that ;)
LOL @ sub .... as long as you wear a skirt to pose :)
veilside copy *shrugs* got a GTR copy on there at moment - doesnt have to be real deal as long as its a bit better quality than whats currently on there!
Aidwin got pics and a pricelist haha ;)
haha Angel as my mum says .... if ya with someone you can window shop but not layby ;) ...... sooo what brought on the question?
age aint something that phases me aslong as its not a ridiculous age gap!! like 15 - 20 years plus!!
I got a thing for Ben Cousins at the moment ...... and ive seen him half naked close up in real life ..... mmmmm haha would love a repeat experience this time not be so shocked that i could actually say something :)
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
