I dont really think the electronic gauges are more accurate. in fact I would generally say the opposite.
the advantage of electronic gauges is in terms of measuring fluids (oil/fuel/water). mechanical gauges require potentially hot/flammable fluids piped into the cabin in pressurised lines - and some of these are illegal. (no mech fuel pressure gauges in the cabin, unless they use a secondary non-flammable fluid as a hydraulic transmitter)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
The gorgeous, vain member of Kyo's Japan Team. Benimaru is famous for his gravity-defying hair and his obsession with beautiful girls. He's 21 years old, half-American, half-Japanese, heir to one of the richest families in Japan, and he has some power to wield lightning while fighting. He lists his most valuable possession as himself.
Benimaru is a great fighter as well as a flashy one, and was an undefeated champion on the Tokyo streets for many years. Until he challenged one of his classmates and found defeat at the hands of Kyo Kusanagi. Benimaru could only laugh at himself, and they became great friends from then on. When the first King Of Fighters tournament came about he agreed to join Kyo's team in it. However, with Kyo being such a powerful fighter, Benimaru is starting to feel like second best. So he's now determined to prove himself and his worth in the tournament.
Benimaru's sexual preferences have oft been questioned, despite his self-proclaimed love of girls, because he looks and acts so amazingly gay. We think he's bi. ^_^ The most obvious pairing for him is Kyo, except that everyone is usually pairing Kyo with Iori. Perhaps they could be a threesome. Another possible pairing is Shingo, who hangs around Kyo (and thus the Japan team) an awful lot.
yep that tall Judo guy with the weeny eyes...
Choi, that mini-wolverine character along with that big fat chainball wielding lardass....haha....
i've got tons of others on my HD, from every fighting game you can name....but i'm not on my PC for at least until next week. damn i hate 56k:(
i'll pm you the link when i get it.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
