  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Nothing much, still trying to cram ure IC in the car but danny is going away for a week so it may have to wait even longer. *sigh*
What i miss in my abscence? i only have a narrow net connection window nowdays, brothers computer :O
Hey Niz.
Yeh heard about ure new and improved monster :(
Dont have a timing light and im trying to get the perfect setting. I keep pulling over on the freeway to mess with the CAS. Cant seem to find the right point of power/pinging. Guess ill wait till the IC goes in b4 i mess with it anymore.
U should see how hard its getting to cram the IC under the bonnet!!! no chance in teh front bar so im gonna need some serious ducting and maybe even a fan to get it to flow nice. Plus my brakes keep giving out on me when i drive hard so they need to be replaced with something a little better. Plus the suspension is just not doing it for me. Oh and the non lSD thing drives me nutz.........any1 got an old pintara gearbox?
well thats about it for me :O
    • Alarm installs, always great to look at 🥲 Then these alarm installers then go and do automotive looms and they end up being a crock of shit.
    • Photo quality is terrible, but there's a few things on that board that give me suspicions it has some issues. Add to that, I'm hoping the cut and exposed wires under the dash were not exposed or touching each other before you pulled that all apart.
    • Stories like this are why the immobilizer installs I've done are 100% reversible. No harness cuts.
    • update; Replaced oem starter motor with a Jaylec 70-61111 car still didn't start, moved over to the alarm system unraveled the spaghetti checked the solder end points, PCB board burn smell, wiring ends, capacitors, water damage everything looked fine restarted car vroom. restarted 5 to 6 time over an hour started put every thing back together only to not have it start any more. looks like i will be removing the alarm system next weekend.
    • Lots of people. Could be a lot of things like people have said. Either the heater hose/pipe, the turbo coolant return that wraps around the back of the engine, or a core plug. I have seen all three. If you want me to guess wildly though I would bet it's one of those hoses for the turbo coolant return. Or the brazing/welding for the Y- section has failed. Get a borescope down there to be 100% sure.
