  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
interesting topic of convo
my parents put the pressure on me last night to decide what im doing over Xmas NYE holidays cos they are going to Tasmania so they need to know whether cats need to go in catteries etc .... so i thought phuck it .... i'll go to Sydney NYE and then go up to QLD for a week :D
I cant really remember the tyre sizes .... 17in 40/50 profile about 235 wide I think???
If it wasnt going to be an outragous cost I would probably go the extra upgrade.... There is nothing worse than the feeling that you cant stop after a high speed run
hooray, afc was sitting on my doorstep when i got home last night... all installed and working fine....
but alas' the manifold is nearly off... just gotta drop the turbo out completely...im having trouble with these dam oil lines i tell ya!!
UGH!! anyone know any tips?
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
    • We want to see pictures of the carnage!
    • The picture of the underside of that PCB shows either old flux that wasn't cleaned properly or some other contaminant (I.E Water). I would flush it with ISO and try again.
    • @silviaz Are you skim coating the entire panel (covering the entire panel with filler) before your hitting it with the long block? Or are you selectively applying filler to the repair, trying to fill the low points?  Please don't do that.  Almost certainly. Are you checking the panel for flatness as you go? Or is it more a case of, sand til all the guide coat is gone then check?
