  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hmmm I have a Nismo front bar but I removed the grill to maximise air flow ( and intimidation factor :D ) but I always fear some smarty pants laying the boot it.... been lucky so far.... had it on a bout 6 months and had no problems...
I wouldnt have thought so, but I spoke to a few people about it when I first put it it...... By far majority I was told to take the mesh out to increase the efficiency of the air flow into the fins....
But I know what you mean ... You get the thin mesh and you think to yourself "Now how is that going to stop the air flowing through" but apparently it does :D
