nah i was on the freeway going north (on the on ramp near the city) and it was an 80 zone (however i thought was 100) and because no one was in front of me, i gave it a bit of stick. Because i didnt see them (they were well behind me), i just kept going faster. They had to acclerate to WELL over the speed limit to catch me (i wasnt running and they knew that).
They were nice guys and said i was at license loosing speeds blah blah blah. Which i was (so no point getting upset at them)
They reduced the speed down a bit so i wouldnt loose my license etc.
THEN they said theres a time and place for everything and havent i heard of ISD's WTF!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeh that was the odd thing. I just played dumb and said i've never heard of them or never been.
I mean the freeway, with little traffic is one of the safer area's to speed. I could have been booting it down a suburban street with kids playing (which i dont)
Ohh well shit happens.
Shuto boy. my mates wrx is phucked. He got a quote to fix it using a JUN stroker kit and MOTEC. 19K all up!!!!!!!
Yeh but paul my insurance will be so high once i loose my license
yeh, ummmm, err GF doesnt know and whatever i spend on my car i just halve :D she would have my balls if she knew how much all this will cost
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
