  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Oil Pressure ...... 8 when you first start it up .... normal engine temps .... 4 when accelarating ...... 1-2 when on idle.
Theres also an old thread about it in General Discussion
When my breaks went wrong everyone assumed it was the wrong rotor, but it was right. They were not fitted correctly, and I believe as a result the calipers stuffed up. Nothing wrong with the calipers before rotors fitted. Very expensive mistake. Go straight to Paul from Tyrepower next time.
Question though... I have been thinking about it..... You want to get larger than average rotors.... I can see the benifts of the slots and k-paw technology but by oversizing the rotors what benefit are you actually getting by larger rotors without larger cailipers /pads ???
Haha just had a practice fire evacuation!!! They made us walk down the fire evac stairs .... this sounds ok in principal but we are on level 18 of QV1.... haha all the poor women in high heels had a great time trying to get down :)
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
