  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ok - as pm'ed to Sydneykid:
Firstly, I will describe my car:
Series1 R33 GTS25t
Mods:
HKS EVC4
3" Turbo back zorst
CAI pod filter
NGK coppers @ 0.788gap
Cleaned induction system - AFM, TB etc.....
Ok, when boosting at 3000rpm/0.82bar i get a slight ping, only audible between those concrete barriers on the highway. I turned it down to 0.76bar and its ok. Whats causing the ping at low rpm? I've done a search on SAU and can't really find any specific info applicable to me. The problems i can think of are:
1. Dirty injector(s)
2. Tired fuel pump
(dont think it the first two coz it seems to be ok up high @ 0.76bar)
3. Turbo is getting hot at those low rpms (fix with FMIC)
4. Just bad fueling/timing coz of stock ECU (temp. patch with adjusting the CAS or get an SAFC as a temp. fix)
5. Blow by gasses leaning it out?
6. Try a colder plug (what do you reccomend for my application)
Could I just reset the ECU so it will learn the increased air flows?
Ross, Are you 100% it's a ping? I run BCP7ES plugs, there a heat range colder than the 6's, gapped to 0.7mm. Stock pump could be going, but you'd expect it to happen under full-load. Might be worth getting injetors flow-tested. Blow-by is more likely to happen at high-rpm.
I'd get it on a dyno, and make sure that it is a ping, then look at the AFR's there the most likely indicators:D
Thats the only time it audible - when the sound bounced off a wall. What else could it be? I think your suggestion for a dyno si the best, that way I can see EXACTLY what the problem is. Hate to buy an FMIC and find out it was just a dirty injector eh.....
    • Interesting. I still think they are the result of impact damage somewhere along the line, but clearly lightning has stuck thrice! I've still got the original ones on my race car and they have had some hard work.
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
