  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ok - as pm'ed to Sydneykid:
Firstly, I will describe my car:
Series1 R33 GTS25t
Mods:
HKS EVC4
3" Turbo back zorst
CAI pod filter
NGK coppers @ 0.788gap
Cleaned induction system - AFM, TB etc.....
Ok, when boosting at 3000rpm/0.82bar i get a slight ping, only audible between those concrete barriers on the highway. I turned it down to 0.76bar and its ok. Whats causing the ping at low rpm? I've done a search on SAU and can't really find any specific info applicable to me. The problems i can think of are:
1. Dirty injector(s)
2. Tired fuel pump
(dont think it the first two coz it seems to be ok up high @ 0.76bar)
3. Turbo is getting hot at those low rpms (fix with FMIC)
4. Just bad fueling/timing coz of stock ECU (temp. patch with adjusting the CAS or get an SAFC as a temp. fix)
5. Blow by gasses leaning it out?
6. Try a colder plug (what do you reccomend for my application)
Could I just reset the ECU so it will learn the increased air flows?
Ross, Are you 100% it's a ping? I run BCP7ES plugs, there a heat range colder than the 6's, gapped to 0.7mm. Stock pump could be going, but you'd expect it to happen under full-load. Might be worth getting injetors flow-tested. Blow-by is more likely to happen at high-rpm.
I'd get it on a dyno, and make sure that it is a ping, then look at the AFR's there the most likely indicators:D
Thats the only time it audible - when the sound bounced off a wall. What else could it be? I think your suggestion for a dyno si the best, that way I can see EXACTLY what the problem is. Hate to buy an FMIC and find out it was just a dirty injector eh.....
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
