  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hmmm maybe hey.
i was in that area (went to RMS) and there near oats street.
If it was in the morning or late arvo it was probably me, if it was between 11-4 it wasnt!
:D it wont be stocker for very long (esp now as i have normal 14psi boost, not the 7psi which my car has ran for the last two years). I have a 3mnth driving holiday coming up, so hopefully i will have a few bits and peices by the time christmas comes :(
Nah when i bought it, it was only running 7psi (which is WELL below stock) and i always thought it was just a dodgy boost gauge.
It was still quickish, but i had to get a few things done at RMS today and they noticed it and basically fixed it all up.
14-15psi is standard on WRX. So much faster than on 7!
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
