  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hmm...
yes yes yes, the skills day was pretty much rained out yesterday. it was wwwwwet!
re: pas, they are continuing the race-bred theme. theyve got video footage of track events and the drift day - and are apparently looking to have time trials with gran Turismo on PS2 set up.
New shirts are being organised, with plastic numberplates as per the thread in the general SAUWA section......um....
SST are organising a pre PAS dyno day for SAUWA entrants...more than that I dont really know.
I think I may be along for the SPL input, but I'm really bummed with how my car looks at the moment, and the stereo is butt-ugly, it just sounds loud.....
I'm not keen in putting my car in for the SPL thingo when mine looks as basic as it does.. I have no special fibrglass moulding or latest amp/sub combos.. or in car tv... or neons - though I'm quite happy about that last one.. :D
but you've got a grand and a half install..
with shiny alpha thingies.
Cam, It's not how flash the thing looks, it's how loud the damn thing is:D So people bring stripped out mini's with 20" subs, even yours will look good compared to that:p
Danny, I think Al managed to cover most things, I replied in the PAS thread:D
paully - what difference will it make if we do/don't enter the SPL at PAS?
i.e., will the broader SAUWA community benefit greatly from our participation and in what way? Im happy(ish) to be involved, but I'm wary of the shopping-list history that PAS has had in the past and although I woundnt mind knowing what my car makes spl wise, I'd rather not be seen to be talking up what is really a pretty basic amp and sub combo..
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
