  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
dammit - stupid flu.. got a blood nose now.. have to sit at my desk with a tissue stuffed up my nose.. people looking at me funny...
bummer bout the rims.. there's always a deal around bud - you just have to look..
