  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
no never neons!! or a GT wing!!
Its going to be a secret ...... if i get this new job with car ..... then mine will just disappear for three months and come back looking quite quite different...... yes but i will own up to the fact checkerboard plating will be going into my car :rolleyes:
i think its time to "personalise" a little bit before it becomes a clone of every other black R33 out there :rolleyes:
But it takes quite a bit of cash .... so depends on job situation whether it becomes possible or not.
Wide body kit is a bit out of the budget .... as is a full respray .... which i would consider if i had the money but $10K on just making your car a different colour i dont think is worth it.
yeah i would love to respray a blue .... :rolleyes: when i win lotto maybe
well as you know rear wing is in desperate need of replacing ..... but no reason to go the whole new kit ..... 400R wouldnt fit on my car anyway without scraping on the ground
    • So I'm going to have to keep ignoring the 4.7 update, or whatever version it is? Poop. I was hoping you'd put me out of my misery.
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
