  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
no never neons!! or a GT wing!!
Its going to be a secret ...... if i get this new job with car ..... then mine will just disappear for three months and come back looking quite quite different...... yes but i will own up to the fact checkerboard plating will be going into my car :rolleyes:
i think its time to "personalise" a little bit before it becomes a clone of every other black R33 out there :rolleyes:
But it takes quite a bit of cash .... so depends on job situation whether it becomes possible or not.
Wide body kit is a bit out of the budget .... as is a full respray .... which i would consider if i had the money but $10K on just making your car a different colour i dont think is worth it.
yeah i would love to respray a blue .... :rolleyes: when i win lotto maybe
well as you know rear wing is in desperate need of replacing ..... but no reason to go the whole new kit ..... 400R wouldnt fit on my car anyway without scraping on the ground
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
