  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
thanks Rob .... can i be vice-president ..... do u have a dart board im in a dart throwning mood.
um no i dont think i am as my name was mentioned a few times .... haha oh well Liz thats funny .... we are so shameful .... how about next time we go out .... we leave our mobiles at home!! :P
well how suss does this sound?
Mum: Kylie, get troy to call me as soon as possable..
K: why whats he done
Mum: nothing i just need to speak to him
K: Tell me why?? Am i still getting a printer for my bday?
Mum: Thats what i need to talk to troy about. Would you ever like to go to bali?
K no mum i need a printer
Mum: how about broom?
K: No mum i need a printer
mum: how about a trip to america?
K: Mum that would be nice but i need a printer!
Mum: Just get troy to call me
No paul from memory you were more concerned about the insurance .... for phuck sake i just had an accident i was in shock i didnt even know where the hell i was let alone trying to work out the insurance ........ then that wasit if i didnt jump on the net you wouldnt of called or spoken to me all day .... and the net .... i am so phucking sick of conducting all the conversations by a friggin computer!!
even people i do talk to on the computer had the decency to call or even send me a message ..... aghhh just get so fustrated.
Anyway not worth it .... just keep repeating to myself ... not worth it.
Kylie ... sounds like you got big birthday surprise coming up lucky girl!! :P
LOL at Liz ........ no cos we try n recruit people to go into the booths with us ..... that night was so funny .... i reckoned they dedicated that song "iim soooo waaaaasssted" just to us :P
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
