  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
me n andrew didnt fight much .... we only had one huge arguement .... maybe two .... or three LOL but still for 2 years thats not bad. Only one where i walked out. There was a lot of eyerolling .... that was about it. My parents have their own huge fights so mine are the least of their worries.
Im sure it wont be the end of our adventures Liz haha .......
Yeh lots of police today. music blaring whilst behind one on Leach Hwy in peak hour. He wasn't imprest, but couldn't do anything. Gave lots of dirty looks in revision mirror, and stuck his head out of the window and looked at me once. I pretended not to see him. Half expecting one to get me further down the road.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
