ive never broken a bone or had an operation (*touch wood*) ..... just only had 4 stitches.
Im soo wussy when it comes to the sight of blood not to mention my fear of hospitals .... even hate going in there to visit people .... such a morbid old people smelling place!! I had to go to the emergency room for a spider bite once and they wanted to keep me over night on a drip .... and as soon as they said that i just started shaking so much cos i was os scared of the place they thought it would be healthier just to give me the antibiotics and send me home to recover instead of stressing me more.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah its ever so tempting
its soughta screwed my plans up for early next year
suppose to get Skyline in January but have to pay medical expenses
then was suppose to go skydiving on 3rd Feb (my 21st :( )
then off to fiji in March for a 2 week surf trip now all 3 of the things i was looking forward to so much will have to wait.
Fiji cool .... yeah i was planning to take a trip after my 21st ..... see how things pan out first. My mum is already like "Where do you want it .... how many people you inviting" .... "im like mum its not til may next year!" "well i need to know to get things rolling :rolleyes:" Mothers!! haha should just elope for my 21st .... get on a plane at the last minute and say goodbye sted of all this party pressure bullshite ...... if this is how she carries on for my 21st .... god help me if i ever have a wedding!!
Skydiving cool .... i had a friend invited me once but i was to chicken and it was a case of "We are driving up to York on Friday to go skydiving (it was wednesday) wanna come?" .... i hadnt had enough time to write my will in two days :(
hey adrian ... wanna a drag? your gemini against my shitbox Laser ... cmon :):(
Wish my folks would ask me that LOL ..... oh well they're paying for it .... i dont care.
So you going with mates/girlfriend to fiji?
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
