  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by ReVN211
lol @ Niz
do you guys ever stop talking about size :rolleyes:
Why do you think they have such big mo-fo wings on the back of their cars? (well cam used to)
its ok boys ...... its all in the width :cool:
hey all :D my first whole day off in ages :D
so sorry paul about not coming last night, at about 6.30 my mates and me were talking bout english translators and then it hit me and i was like ohh shit i was suppose to be at fast eddies :cool:
adrian :rolleyes:
Paul,
I thought you knew that bloke who is running this, have you pissed he off or something, I think that we make numbers for this space and keep it small, and then set up the outside are for other part of the club theme, just have two SAU areas, it that your thinking???
this morning i woke up and my shoulders are killing me, then i asked myself why do i put myself up to this torture at the gym :D
hehehehehee it's all good NO PAIN No GAIN :D
adrian :rolleyes:
then i slapped myself for questioning why i doing it :cool:
yeah pauly i realised i wans't missed after i realised u didn't message or call me to ask where i was :D hehehe
and for the record at least i don't always slap my meat hey buddy, u like to ride him rough :rolleyes:
adrian :cool:
is it me or are you advoiding the subject where we are staying ...i dont mind asking once .... hey i dont even mind asking twice .... but when ive asked about 5 times and still get no ansewer i start to get a little bit pissed!
