  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hehe Lee .... what University did you go to .... sounds liek we might have been in the same classes :rofl:
Nah i didnt like that idea ...... was thinking two small ones on my rear windows ..... and maybe ..... depending how it looks a medium sized one on my bonnet just above my passenger side headlight. I might give the rear window ones a skip and just have the one on my bonnet ..... in silver.
i knew what ya meant lee. Thing is its all good in theory but im one of these less is more people ..... and i'll probably buy all these stickers yet only use 20% of them because i dont like my car looking like a billboard on wheels.
aaaahhhh thats the reason behind castrol sticker ......
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
