  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Bwhahaha..... i love it. Went to tyrepower yesterday and paul said "yeh paul came in and his girlfriend got these tyres"
thought id ask :)
The prices there arent too great are they? go round the corner and it drops $20.
yeh doin fine Niz :)
LOL @ Paul .... thought i would answer so u didnt get in trouble :)
tyres are good Boosty ..... pretty sticky haha constantly hear them picking up stuff but they seem to be wearing good and gripping good :)
just 99.9% eh paul :) ....... nah im not a nice person to be around at the moment ...... take my car away leaves very grumpy girl!! But gym is helping ..... i went again last night .... spent an hour n half there .... get home and im too tired to be pissed off :)
Alex - tell me about it!! i feel so tired today ..... i plonked myself in front of the TV this morning and that was it ....rather hard to get up again :)
Sometimes i wished i drank coffee.
So i take my car to the sparky yesterday and say
"ok the dash is on the back seat and the tacho gets power but it doesnt work"
After leaving it for a day they say
"ok the dash has been taken out and the tacho is getting power but it doesnt work, we need more time, cant u leave it overnight"
Ergo my car is still at the sparkys and im gettting lubed up while waiting for the bill *sigh*
Ud think an auto electrician would know how to fix... hmm i dunno....electrics in an auto!!!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
