  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
I'm always nice to cops when they pull me over, but some of them want to do you no matter what.
no your not - your pretty arrogant. When they pulled Aidwin and you over that time im sitting in the car and thinking "no, no dont say that .... dont pull that face .... ok ok he's going down now" and you wouldve had they had your speed.
I think it was a $100 fine and 6points he had 12 from when he last lost his lic (continued drving anyway)
He drives pissed all the time and keeps getting nailed by red lights and speed cameras. Losing his lic might have taught him a lesson.
Not like "oh im gonna take the back streets home its only 2 suburbs over" etc. More like "ahh im hell pissed im gonna drive to northbridge and back"
yeah im going to be more careful this summer too ...... i used to constantly drive back from the Cott pretty rolling .... and thats like 45 mins from my house ..... but then again they may have knocked the hotel down before then anyway :P
Paul: your sad.
Niz, I'm not sad, I'm quite happy thanks:p
Smart Arse :slap:
I get over 6 points back next year .....go lauren its ya birthday Woot!!!
WHERES jerry springer forums???
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
